Help B6 TOUCHING FIREWALL OF FORD FESTIVA HOW TO FIX
  • Help B6 TOUCHING FIREWALL OF FORD FESTIVA HOW TO FIX
    Hey guys its my first swap ,from a 1.3 to a b6 dohc 1.6 but i run into a few problem and would really love some help here in jamaica. the problem i am having is my b6 engine is touching the firewall of my festiva and causing the car to vibrate any trick or solution is welcome, thanks in advance
    Put spacers between the front of the transmission cross member to body mounts. You must be using some weird jdm intake if it's hitting the firewall.
    Better Than Nothing Racing
    Way too many cars
    :woc:
      no bro i am using the stock b6 intake
        can you show pictures of the motor mounts and under the hood in general?
        19?? 150$ burnout car SOLD
        1991 (STRESS RELIEF)SOLD
          i wonder if he has that 16 valve SOHC head. i had or have that and remember the intake being a good bit longer than the 8 valver.
            ^the 16v sohc is tight! If it's on the stock trans do as shorestiva said and space the crossmember down.
