Over the past year, shifting my 5 speed 90 Festiva has become increasingly cranky. It does shift but moving the stick thru the gears isn't smooth. I'll call it notchy, a term I recall writers used to describe less than smooth shifting manual trannys. It doesn't pop out of gear. That is, otherwise it operates normally. The shift lever doesn't move up and down.
I'm wondering what the symptoms are for a worn shift mechanism. And can it be serviced or repaired from the top or do I need to get under the car. (Ouch! Getting too old for that) Thanks in advance
Charlie Z
Semper Fi'steva
Charlie Z
Semper Fi'steva
