My cooling fan fuse in the dash keeps blowing. 20A fuse, if I unplug the wire on the thermostat (fan should be always on) - it immediately blows. If I put a 30 amp fuse in, it will hold. When I did this the fusible link for the main (middle one) started smoking so I took it out, cleaned the contacts, then put a PAL 40A fuse in - no more smoking.
I've looked around and can't see any grounds but there is a splice in the wires to the cooling fan - would this be a cause of high amp draw?
what else should I check for?
