Loss for words
  • Loss for words
    Ok so I replace piston rings and valves and the dam car still don't fire. I don't know what else to do
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    How are the engine ground straps? Clean and tight?
      What are they
        They are heavy gauge copper wire with brass eyes. They bolt between the engine and the body. The engine must be properly grounded. Everything must get back to the battery. Electricity travels at the speed of light.
        Do you have the proper firing order?
          Ok I got it fired and it runs now when I hooked up the radiator and poured antifreeze in it's now leaking out on the passenger side of the oil pan but it's not in the oil and I can't see where it's actually coming from
            Water pump is leaking .
            New build on the way .
              Yea just found it.
                Sounds like waterpump leaking down inside timing cover.
                What did you do to get it to run?
                  What kind of Compression are you getting in each cylinder? You may be a tooth off on the Timing.
                    What was the no fire issue?
                    19?? 150$ burnout car SOLD
                    1991 (STRESS RELIEF)SOLD
                      Lol never pour in antifreeze til you know everything is good to go. Just water. Save you money and a mess.
                      91GL BP/F3A with boost
                        Usually a good idea to flush these older engines a few times with water anyway before adding coolant.
                          Just dont forget to drain some of that water after and dispose of it properly when you add more antifreeze. I think it was the second year i had my festiva i put too much water in and forgot to drain some out and add coolant later. It was still very green so i never thought of it after i forgot... i had a 2hr drive in -20c temps with no heat. Didnt realize that my coolant had frozen until about half way through the drive. That was cold, i wasnt dressed for bo heat...
                            The battery was just completely dead. After charging for about an hour with crappy jumper cables it fired.
