Ok, so I acquire a parts Festy for cheap (parts swap), knowing full well that the engine had "issues". Finally got around to firing it up, and it idles ok-ish, but with an occasional clatter. It will actually move under its own power, but not happily: with all sorts of clattery-knock-y badness.
It has oil, fresh gas, but after driving around the block a few time, the oil light started to flicker on. I pulled over and turned it off, and after letting it sit for a bit, I made it the rest of the way around the block without the oil light coming on, but still clatter-rific.
Is there any reasonable way to determine the source of the clatter without committing a ton of time or money? I didn't buy it for the engine, but I am curious if it is redeemable. I have strong evidence that it might only have 100k miles on it...
Thoughts?
Thoughts?
