Engine Assembly Questions
  • Engine Assembly Questions
    Starting to put back together my rebuilt B3. I got one of those crappy springed, racheting, band type ring compressors from a McParts store and its not working well at all, so I was going to get a Matco Ring Compressor set Part Number: MST75A, but it says the smallest compressor is 73mm. Factory bore size is 71mm. The shop bored the cylinders, but I'm not sure exactly how much. I will end up buying this set sooner or later, but I was wondering if I should look for another option first...
    A mechanic knows how; A technician knows why.
    Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
    Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
    Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
    FB Festiva page: Jared Bennett
    Instagram: jaredbear82
    Can you measure the diameter of your new pistons? If they measure 73 mm get the Matco set. If you are under 73mm keep on looking. Have you checked with Napa? Their top lines are usually pretty decent quality.
    '88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
    '93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
    '91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
      Will do.
      I'm going to be using a B6 exhaust manifold. Should I use the B3 gasket or the B6 gasket?
