Need help ASAP Festiva blows fuses?????????????????????????
  • Need help ASAP Festiva blows fuses?????????????????????????
    Hey,
    Guy I put over 2000 in my festiva
    super tune up
    put new alternator baterie
    all new fuses and all
    Each time I take it out.
    I drive it not even onw minute and it blows the fuse under the hood where its kinda of a wired fused in a small black box
    there is 2 in there.
    You cna let the car idle all day it will be good.
    But drive it one minute and it dose a buzing sound and stalls
    cant start it
    turns over good but does not start
    replace the fuse works perfect for one minute.
    Mecanic dont know the hell whats wrong.
    took it everywhere
    Please guys try to help me with this
    thanks
    Please tell us what you have. We cannot guess if you have a carbed or FI car.
      1992 Ford Festiva EFI automatic
        any help guys?
          So if the car just sits ,it will idle all day with no problem.
          When you drive it happens , so when things move wires move , I would check all your grounds ,and look where the harness runs thru the firewall , Did you replace your fusible links with plug in fuses?
          What fuse link is blowing ,left ,right ,or middle one ?
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
            to be 100% I dont know which one is blowing.
            its driver side under the hood. the fuse box furtest to the front end of the car
            fuses are wire fuses not boxed fuses
              OK so which one blows ,there should be 3 in that box , left , center and right one . That may help determine which area is affected .
              Z28 LS1 power 500 +
                The 3 fusible links should be labeled on the fuse block. The head fuse is for the headlights, the EGI is for the fuel injection, and the main is for everything else. This is the fuse block located on the left strut tower ?
                How come you put all new fuses in it during super tune? Were they blown prior?
