What transmission sealant? Does anyone have a 5speed exploded view?Gears can fall in!
    Originally posted by ricko1966 View Post
    Thanks for all the input, I've already made a decision going to go ahead and pull engine and trans out the top as an assembly. Going to go ahead and do a 5speed swap while the engine and trans are out.As for pulling the engines and transmissions all the festy engines I have pulled were in 4/5 speed cars and I took them out the top as an assembly,All the transmissions I've pulled were 4/5 speed they come out the bottom fast and easy I have my own method that I think is fast and easy. VW golf jetta when you pull a manual trans/engine nbd unbolt everything pull it up like a 5 speed festy. Autos you have to drop the subframe and pull the crank pull to get clearance.Any thing different o n pulling auto festys vs 5 speed festys. I hate surprises
    That was supposed to say you have to drop the subframe and remove the crank pulley on the auto jetta/golfs
