Ok, I fix one problem, now I have another. Purchased a new battery for the festy because the other one tested bad. Went to put it in and all it does is click at the starter. Is it a connection issue or a bad starter? The connection is tight so I'm thinking its a bad starter. Do starters normally go bad in the festies? I never had an issue like this on a festy and I'm hoping with someone with experience can help.
When I pop started it with the clutch, the festy runs great!!
The transmission was recently replaced with a good one.
