So during Madness this year a 91 Surf Blue came up for sale in my area. The seller stated that the car had issues but it looked too good to pass up so I bought it sight unseen.
Issue #1 is blow by. The engine has a major amount of blue by, so much that the intake hose from the air filter to the throttle body has so much oil in it that I was able to "pour" it out. I pulled the PCV valve and it rattles freely but I cleaned it anyway. I took a compression check and each cylinder was 140-150. I squirted oil in each cylinder and did a second compression check which resulted in a gain of 2 pounds in each cylinder.
What should I look at next?
Issue #2 is that the car drives along fine for 15+ minutes and then quits. It just dies, no missing, no sputtering it just dies. If it sits 15-20 minutes it will start back up and run like a champ until it decides to die again. I swapped out the coil and associated parts (ICM and little black square) with one that is known to be good. It still warms up and quits.
The last time it quit the friend who was there to tow me pulled the coil wire and shorted it out as I attempted to start the car. There was no spark coming out of the coil.
Distributor?
Thanks.
Distributor?
Thanks.
