So here's where I'm at. The right control arm bolt is loose and spins. I searched and read for an hour or more so I know exactly why it's happening and have a good idea on how to fix it, however I have a few questions regarding this somewhat common issue that I didn't see answered elsewhere:
1. The metal cage is still there but I used a screwdriver wedged in there from the factory bottom access hole to try and tighten the bolt and all it did was tear and distort the cage. Am I supposed to be trying to just break off what's left of the cage now? It seems pretty solid.
2. I plan on drilling a 3/4" or 1" hole on the inside of that "frame rail" to access things (what size should I be using??). Then I can use other tools like pliers or a wrench to tighten it, plus it will make future replacement easier.
3. The new bolt that comes with the Moog control arm, is it for the body/frame end of the arm or is it for the ball joint pinch bolt? It doesn't say. https://www.rockauto.com/en/moreinfo...8248&jsn=16597 - I plan on ordering 2 from RA but for now I want to get my front end tight so it's safer to drive in the short term.
4. When I actually get to replacing the control arm, do I need to disconnect the strut from the knuckle and take out the axle like that YouTube vid shows? It seems to me from what I've read I should just need to disconnect the ball joint end from the pinch bolt, then the sway bar bushing section, then finally the "frame" side bolt last.
I already know about using penetrant ahead of time and anti-seize etc. during the replacement.
Thx.
Thx.
