Title says most, I put a clutch in today, and the pedal does nothing. i can hear the throwout bearing barely make contact with the pressure plate when I move the shaft the cable attaches to all the way to the end of it's travel. Did I miss something? I feel like a dope, I've done plenty of clutches but this is a new one on me.
New clutch, Won't disengage. Where did I mess up?
Shift linkage is connected properly right? Both bars bolted on there and it is for sure in gear?
How far do you have the cable adjusting nut tightened on the transmission fork? Should be able to have a bit of free play on that fork, nut cant be too tight. Take the spring off the fork so its easier to check freeplay. Then put spring back on.
Can you post a photo of how tight you have it?
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 11-14-2017, 06:48 PM.
No i put the clutch in, and when i was going to install the clutch cable to the fork i noticed it's just loose. The arm that attaches to the fork pivot is as free as they come, it's obviously not contacting the pressure plate. This is bypassing the cable/pedal mechanism, going solely by what I feel at the transmission. I installed the cable for the hell of it but the pedal just goes right to the floor.92 Festiva L with AC
5 Speed, 244,000mi and counting!
R.I.P. Zeus, aka 77 F150 Custom Explorer 300 I6
Go Green! Go White!
did you possibly put the clutch disk in backwards it would cause those symptoms or the bolt that holds the fork to the clutch rod is missing88 L carb'ed (when up in flames of glory)(deceased) 4spd
89 L carb'ed (died on the operating table (rust))(deceased) 5spd
93 gl FI (sold) automagical
89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
88 L carbFI megasquirted zombie car
I'm pretty sure I installed the friction disc correctly. I guess i'll know when i have the transmission back out, Thanks for the thoughts y'all. I just wanted to see if anyone had run into a similar predicament before I pull this transmission back out. I really don't want to battle the sway bar again but looks like i'm stuck.92 Festiva L with AC
Go Green! Go White!
Here is a pic of both sides of the clutch disc.
Which one did you face forward?
The left hand disc or the right hand disc?Last edited by bravekozak; 11-15-2017, 06:26 PM.
I'm a dope, the throwout bearing fell out in the grass when i was cleaning the transmission up. I had trouble putting it through the driver control arm with new bushings.92 Festiva L with AC
Go Green! Go White!
Oops... you found the bearing back though and its all good now?Originally posted by notyettoday View PostI'm a dope, the throwout bearing fell out in the grass when i was cleaning the transmission up. I had trouble putting it through the driver control arm with new bushings.
I had trouble with that once as well. I think i took off the one front sway bar brace, put the foreward lca bushing on, put it through the lca, put the rear bushing on but still couldnt get the nut to start threading with the cup. So i tightened the nut onto the bushing with no cup for a ways. Backed it off, put the cup on and retightened.
Yeah bearing installed and i'm good as gold. I thought about doing it that way, i've done that on sway bar links on other vehicles before. i was having trouble getting the sway bar to go through straight to be able to line the rear bushing up with the bore in the lca. I he-manned it and got it after plenty of cussing. I just dropped the forward mounts to the core support and the spindle to strut mounts since i'd already replaced the bushings and i had enough clearance to slide the crossmember back. The new shifter linkage bushings installed as well, it shifts absolutely beautifully now.92 Festiva L with AC
Go Green! Go White!
