So two weeks ago I bought the parts to replace my cv axles, struts, and ball joints on the front of my 91 festiva. The struts did not come with new coils springs and I can not find any place to buy them anywhere I have looked on the internet, on top of that I can not find the specs for the festiva coil springs so I do not know the lb/in rate for my car. All that would have been moot if one of the springs had not cracked when we went to recompress them to place on the new struts. Now I need to find a replacement set, but I do not know which car brand might have equivalent coil springs. Any help would be much appreciated. Also, I am not looking to pimp out this ride, yet anyways, I just need something to get my girl back on the road again.
Front Coil Springs
People have substituted Kia Rio struts from junk yards. I think the springs are higher but can probably be cut down for your strut assemblies. Iinfo archived in this forum if you want do do a search and check it out.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Ok, i dont know of anyone in arkansas. But there is a map of festiva owners. Have a look and if you see someone close to you then you could pm them about springs to see if they have any. Heres the mapOriginally posted by SpamCan View PostNope Cabot, Arkansas.
Do you have a wrecker close to you with festivas or not?
Here:
2002 MT Kia Rio front springs
.445" wire diameter
4" OD
7 active coils
175# spring rate
99-00 Racing Beat Mazda Miata Lowering Springs (pn54018 )
.460" Wire diameter
4.25" OD
6 active coils
193# Spring Rate
1994 MTX Aspire Rear Spring
.375 wire diameter
3.9 OD
7 active coils
90# springs
1997 ATX Aspire Front Spring
.406 Wire Diameter
4.125 OD
7 active coils
106# springs
1993 MTX Ford Festiva Spring
.402" Wire Diameter
4.25" OD
6 active coils
107# Springs
stock Festy rear spring (80 lbs)
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 11-24-2017, 06:37 PM.
