spark plug change comming soon.
  • spark plug change comming soon.
    i am the second owner so i would like to put in a good new spark plug.
    should i change them hot or cold ??
    any advice so i dont break them off in the head.
    or is that just what might happen no matter what???
    if i do get them out with no problem what should i replace them with??
    besides a good helping of antisieze.
    shayne
    Next plug I put in will be Denso Iridium. Don't change your plugs hotter or colder unless you've done something to make it worth while.
    -=Whittey=-
      sorry
      what i meant is should i attempt to remove them when the engine is hot or cold???
      shayne
        Cold
          put antiseize on the new threads to avoid worry when they have to come out again.
