1988 ford festiva, manual trans, manual steering
I ordered this part #2968 from detroit axle. Labeled as "Complete MANUAL Steering Rack and Pinion Assembly 1988-1993 Ford Festiva"
The car (dads) is 6 hours away and a shop is doing the work. The shop says the replacement is an inch longer and bigger in diameter. What is the correct part # and where to get it? I am waiting on the mechanic to get back to verify if aluminum or steel housing (old and replacement) and if tie rod ends will match up.
I did do a lost of searching but could not find any definitive answers.
