I have replaced (1990 1.3 fuel injected 5 speed) Air idle control valve, the t stat, the temp sensor, the air canister purge solenoid, fuel pressure regulator, the MAF, the fan relay, the Idle position sensor, full tune up, the catalytic converter, the injectors, the muffler, etc... It runs great, but sometimes it will idle, but most times it dont. I come to a light, and DEAD! Driving me crazy. Even one of the areas most talented mechanics is scratching his head. There really isnt any bolt ons to fix anymore. Compression is good, oh I even replaced the engine gaskets. Is it the Engine control Module? PLEASE INPUT!!!! Have a nice day.
ahh wont idle
Mine does it once in blue moon and I think its the dash pot....you'll see it behind the "throttle" or you can google it to get a general idea....mine is okay but I can tell it compresses too quickly which leads to the severe idle drop resulting in the engine dying. Maybe I'm way off....but thats my take.92 GL, 98k
77 Chevy shortbed
There is also aj "electronic dashpot" in the ECU. Make sure the throttle pposition switch works and is adjusted properly, check function at ECU plug to verify good wiring, if thats all good, I'm guessing cracked solder joints on the board in the ECU. Easy to fix on the bench with a 10xsmall magnifying and 15w iron.No car too fast !
Which Temp sensor did you replace?Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
