My left CV is clicking a bit now turning right- I've heard this is the sign it needs replacing. I have two new shafts out in the garage, ready for installation.
My questions are then these:
How long can I keep driving this, and what are any consequences or other damage that could happen.?
Obviously it's the dead of winter-the noise isn't very bad -no where near constant- only turning- and I haven't enough time yet to tell if or how fast it might get worse.
and then-what kind of cost is a ballpark price to have the new CV's put in? What else might be needed or expedient to have done at that time? Could it be something else like a front bearing? Is that good to have replaced if the assembly is off for the CV or vice versa?
It's a 96 Aspire, 127 K with press in bearings- so that has never been done
Also, is there any procedure to buy time? Has anyone put a small hole in the boots and put gear oil in them or anything like that?
Thank you for replies in advance.
. If the hub bearings are tight and quiet, leave them be.
ccasion5:
RUIDD:
