My latest speedo cable is now making the dreaded ticking, rubbing sound. I changed it before but I forget how I did it. Anyone have any tips on making this job easy?
SPEEDO CABLE.........
Try just cleaning it out before you replace it. They can be lubedOriginally posted by denguy View PostMy latest speedo cable is now making the dreaded ticking, rubbing sound. I changed it before but I forget how I did it. Anyone have any tips on making this job easy?Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
You remove the cable by unscrewing it from the gear its attached to from off the top of the tranny. If you need a new cable, Jim Davis has some.Last edited by milehighbear; 01-23-2018, 07:32 PM.
Once the cable is disconnected from the transmission I push the end up into the engine bay before pulling the cable out of the housing. That makes it easier for me. You can put the end of the cable in an electric drill for testing. Go easy until you see which way the drill needs to turn.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
As Will said, it probably just needs to be cleaned.
Disconnect it at the tranny end, pull the cable out of the sheath, clean it real good with something like WD40, then slide it back in. You can put graphite or something on it but I often just leave them with a thin coat of WD. You'll have to repeat every few years.
If you ignore it too long the cable will break.~Nate
Current cars:
FOTY 2008 winner!
