I was told by the alignment shop that i had too much play on the steering rack. But didnt tell me the exact problem. I put the car on the jack and wiggled the right front tire back and forth and herd a clucking sound near the right bellows boot. what could that be the problem a inner tie rod or bad steering rack?? How do i check a bad inner tie rod??
rack and pinion or inner tie rod?
Festiva in the air
wheels turned to the right ( for checking the left inner tie rod)
hand on boot (you will feel the inner tie rod end)
other hand turn the wheel
you will feel the play -if any - before the joint
or you can remove the wire tie holding the boot to the rack and observe
reverse for the right side
