My front-damaged 93L 5-speed is a perfect car (cars don't rust here in WA) except that it apparently has been smacked hard squarely on the front bumper. This caused the front unibody plate (to which bumper, headlights, and extreme front of fenders attach) to get pushed in. The fenders and hood are in perfect shape -- not even scratched. The car drives perfectly straight.
I took it to a body shop today asking about having the front panel pulled back to straight. They suggested replacing the part instead. It seems to be spot-welded on to the rest of the unibody in at most a few dozen places, maybe as few as 20.
Here's what I'm thinking of doing:
1. Center-punch and drill out all the spot-weld locations, all the way through the front plate and that to which it attaches with, say, a 1/4" drill.
2. Repair any other damage now visible (the fore-aft "box beam" on one side is partially caved in on the inboard side).
3. Remove the same part from a donor body (I have two of these with no front damage), being careful to drill the 1/4" holes in the front plate in exactly the same places as on the recipient.
4. Fasten the donor front panel to the recepient with short 1/4" bolts+nuts. In tight spaces, I'd use aircraft "missle" nuts which are very small. I don't know anything about riveting.
Am I crazy to be considering this kind of repair? Has anybody done this before?
I fixed the car for my self to use. I don't plan on ever selling it, and I can watch this area for cracks and such at oil changes and maintenance times. I doubt this will be an issue in such a light weight and low torque application. If I ever did sell I would fully disclose what was done, but by then it will have proven itself a durable repair.
