any info pls. already changed distributor, coil, plugs, and just about anything else i can find. but engine will still not rev up. it almost sounds like its getting no gas. any ideas guys
changed the vaf today also fuel pump. still the same hmmmmmmmm :? problem solved dang repair shop put distributor back to gether wrong, had the post that rotor goes on in off center also timing belt was out 3 notches :evil: 3 day of searching grrr :evil: now it runs just perfect
