Turn signal/head light switch wiring
  • Turn signal/head light switch wiring
    Does anyone have a diagram for each plug on wire purpose from the stalk assembly I can't trace each wire through the rats nest left here
    Sent from my SM-N950U using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    Post 753366
    Follow the links.
    Good luck.
      Originally posted by bravekozak View Post
      Post 753366
      Follow the links.
      Good luck.
      Thank you very much
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
        I cannibalized another harness to replace the cut radio speaker wires in my 89 harness.
        I popped out the terminals and did a perfect replacement. No one would have ever known they were chopped.
        I am using and 89 harness in my 93GL.
        There are two six position connectors in the lower stalk.
        You should not be able to get them mixed up, because one of them has a piece of plastic in one position.
          I gotta print those out trying to look at them on my phone is mind boggling lol but oh nice I didn't notice the difference just got lucky with the wire lengths lol
          What I'm trying to do is a rewire of the chassis the engine harness is very much intertwined with the chassis harness and I'm having a hard time pulling one terminal free it from the harness and reconnect it lol I freed the wiper harness that was quick
          But I figured since the wiring is over 20 years old just replace it reuse connectors and get new terminals
          Festiver
          93 L find/5 speed
          BP/g15mr swapped
          89 festie
          rustful
          93 festie
          advanced suspension
          kai/skeeter camber
          b3t/g15mr
            You can get brand new Yazaki terminals and connectors (used by Mazda) from easternbeaver.com
            I added a couple of extra circuits to my Festiva wire harness. Like, cruise control, power antenna, progressive power locks, power windows, dash clock, lighted vanity visors and fuel filler door actuator.
              Ooo write up on the filler actuator and power locks?
              I bought a cheap power lock kit I'll see how well it's made but I'm interested how you wired yours did you reach the horn and lights?
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
                power door locks
                gas door popper
                Festiver, there's a search box at top right corner of every screen.
                Be sure to use double quotes for word strings.
                  power door locks
                  gas door popper
                  I'm sorry for all the stupid questions I use tapatalk almost always the downside is the search function brings up very little results for me I tried "powerlocks", power locks, powerlocks ,"power locks" all brought up only 3 threads all about completely different topics
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
