1990 festiva front wheel hub assembly
  • 1990 festiva front wheel hub assembly
    Hey, I need to find a front wheel hub assembly for my 1990 festiva that is also my daily driver does anyone know where I can get one?
    welcomsign
    Welcome! Check if either Rear Counter or Four Green has the parts you are looking for.
    Many members have installed Aspire hubs with larger rotors and calipers for improved braking.
      Try the buy-and-sell forum on this website. I rebuilt a pair of front wheels from a junk yard. Junk yard Festivas seem to be getting fewer and fewer. Good luck.
        What’s wrong with your hub? Where in GA are you located?
        Jerry
        Team Lightning
        Owner of Team Lightning
        93 L Lightning. BP
          I'm in Kennesaw and the metal on my hub is worn Dow from previous owner riding on bad bearing
            So there are a few options for you depending on which side you need.
            1. I just rebuilt a Hub that I will not be using that I can sell you with brand new Rotor but i took off the dust shield.
            2. I can sell you a used one and you rebuild it.
            3. Aspire Hub & Brake Swap
            4. Capri Hub & Brake Swap
