Moses lake
No starting no gauge lights
Check for spark at the plugs.
If spark, then check for gas.
First, reach inside the right rear access door and make sure the inertia switch isn't popped up.
If up, then push it down.
The next thing to check is the fuel pump relay (just below the dash on the left wall).
If good, then, the VAF (vane air flow).
Good luck.Last edited by bravekozak; 03-20-2018, 07:41 PM.
