Hello everyone, I'm having brake issues. About 2 weeks ago I changed the drums, bearings, wheel cylinders, shoes and all the little springs. When I went to bleed them I couldn't get fluid out of the back passenger side. I then removed the master cylinder and made sure it was pumping fluid out of both ports. I bench bled it and reinstalled it but still no fluid to the back passenger. Next I changed out the proportioning valve with one off of an 89 Festiva and behold there was then fluid to all 4 wheels, great! After bleeding the ever loving hell out of everything again I took the car on a test drive and had nice full pedal, until I didn't. Now the brakes sporadically go in and out at random. Ill be driving along and hit the brakes and the pedal will go to the floor with minimal effort, I'll let off it and hit it again and then have full pedal like I'm supposed to. I've made sure everything is tight, Ive bled everything again. I'm out of ideas at this point and tempted to cut the floorboards out and start doing like the Flintstones!
I have brakes, and then I dont.
I would put my money on a new master cylinder. It sounds like it is bypassing internally. You wont see any fluid leaking out nor will the fluid level drop in the reservoir.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
I agree. I think the valve was the problem at first, but the piston in the master cylinder normally doesnt travel very far. Junk can get built up in the cylinder bore and the seal gets old. When you go to bleed brakes in the car and push the pedal all the way down the cylinder travels way further.
Same as when bench bleeding. Very likely the seal in there got scored up and sometimes bypasses, sometimes doesnt.
Be careful getting a reservoir at the same time, Make sure it has the level sensor,the one I bought did not.In a perfect world we do not need the level sensor,unfortunatley we do not live in a perfect world.Originally posted by Studebaker View PostGo ahead and buy the MC with the resavor. Changing them over is not worth the effort.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
Got the new master cylinder (with resivour and sensor) and everything is working as it should now! My brake light is staying on now though for some reason. Everything seems fine though. Thank you all for your helpful input and thank my ol lady for who is entirely done with pumping and holding the brake pedal
