Just pull the injector out and plug it in to the harness and see if it is firing fuel while having someone else try to start the car. It isn't terribly hard to get them out just make sure you don't loose the plastic spacers that the bolts go through and if you pull it out I would replace the O-Ring on the injector before re-installing.
Need help getting engine started!
