I have a 91 festiva. It starts but then dies after about 2 seconds. I replaced fuel filter and fuel pump. Seems like a fuel problem. Any ideas?
starts then dies after 2secs.
At least you tried after....
That sounds like a vacuum leak to me but could be something different. Have you checked for CEL Codes?"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
You might have someone spray carb or throttle body cleaner into one of the small ports on the intake when you start it and see if you can keep it running - but still could be vacuum leak or VAF concern. May eliminate ignition concerns.186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
True Brave, but he states that its a 91. That should be EFI unless.....Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
When mine did that it was the ignition control module. It was at a garage and the mechanic said that was what it was doing and suggested that might be why. I shopped around and got a new module and that fixed the problem. What was the engine doing before this happened? Was it stalling out and starting after the engine cooled down? Mine is carburetted but I think the icm problems and symptoms are the same.Last edited by WmWatt; 06-26-2018, 11:17 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Then the VAF may be stuck. The EFI fuel pump relay needs to see the VAF signal or else it shuts off the fuel pump after starting.Originally posted by Team Lightning View PostTrue Brave, but he states that its a 91. That should be EFI unless.....Last edited by bravekozak; 06-27-2018, 04:00 AM.
Yes, make sure something like A/F grit is not sticking the VAF closed, I've had this happen after changing air filter, car wouldn't idle - but could keep it running with a little throttle. I think mine was stuck part way open.186,000 miles per second is not just a good idea, it's the law
1992 aqua L (agua)
