5 Spd Shifter Stabilizer Bar
  • 5 Spd Shifter Stabilizer Bar
    I had to make a new rubber bushing for the trans end of the bar. Like to know if that metal sleeve in the bushing is supposed to pivot on the trans mounting stud? If so, how do you keep it free to turn after putting on the stud nut?
    iirc the nut doesn't get tight enough to stop the oem one from moving but I don't think that it needs to move much if any.
