So i just got me a 1993 festiva, its EFI, its also been sitting
So far i've replaced the fuel pump, filters, and TPS sensor as those were obviously broken parts.
Turn-key, cranks fine, all info-lights on dash illuminated. Can hear the new fuel pump whining away.
Checked spark with a plug-in tester. Bulb flashed on all 4. Good.
Pulled spark plugs, all 4 wet with fuel.
Dropped engine and checked if timing was correct, it was.
Checked the air-door on the air-filter sensor 0 gunk and swings open easy.
Have not ran a compression check yet.
Looking for some more "test" info to run on this car to hunt down this no-start issue im having. If anyone has any pointers.
Thanks.
Thanks.
