Does anyone know if an early KIA Pride grille will work on our Festys without a complete conversion, headlights and all ? (or be made to work) It is the one with a top to bottom center "nose" and 2 horizontal bars on each side.
KIA Pride Grille ?
You need the headlights and grille, I know that, but I don't think you need the fenders.Current cars:
i have the later pride stuff. the trim under the light is different, and i was told the early ones are the same.
you can see where the trim meets the grill its all different
20180708_095528 by Brandon Hobock, on Flickr
CURRENT. Past
88 festiva L. 89 xr4ti
14 foST. 89 xr4ti
82 F100. 97 silverado
82 GS1000. 06 h3
82 GS750. 79 ta 6.6
74 TC185. 89 turbo katana 600
69 T500. 80 gs1000
15 sonic 82 cr480r
The one I like has an angular 2 vertical bar "nose" and 2 thin horizontal bars on each side. I have looked and the headlights are relatively rectangular like Festy's, but they must be wider because the lower bar that meets the headlight fillers are longer. Does anyone know for sure if the headlights are different, or if you could make it work - somehow ?186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
Yes, the angled headlights on the pride are different, they are longer than the Festiva lights.Originally posted by hot4dl8ly View PostThe one I like has an angular 2 vertical bar "nose" and 2 thin horizontal bars on each side. I have looked and the headlights are relatively rectangular like Festy's, but they must be wider because the lower bar that meets the headlight fillers are longer. Does anyone know for sure if the headlights are different, or if you could make it work - somehow ?Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
Does anyone have the KIA part numbers for the longer than Festiva rectangular (Early) style headlamps. Looking on a website, there are part #'s - no pictures.186,000 miles per second is not just a good idea, it's the law
1992 aqua L (agua)
