Leaky Front Crank Seal
  • Leaky Front Crank Seal
    It seems to not leak if I run it a quart low on oil. Time will tell.
    I hope this doersn't mean you plan to run the engine a quart low on oil.
      Even running it low, it'll spit oil on the highway. Guaranteed, ask me how I know.
        Ive had 2 festivas that had the front crank seal go. They spit out less oil when running a quart low but they just keep getting worse until you replace the seal and replacing it is easier than damaging your motor from running too low on oil by accident
          I Agree with ryanprins13. The oil slinging makes a big mess, takes a big risk on engine damage and I think the oil deteriorates the timing belt.
          186,000 miles per second is not just a good idea, it's the law
          1990 yellow L+ (l8ly)
          1990 yellow L+ (sunryz)
          1992 aqua L (agua)
          1993 blue L (aurora)
