Trans support
  • Trans support
    Any ideas besides padnos?
    Sent from my 2PS64 using Tapatalk
    Cut the whole core support out and replace it with 2"x3" angle iron.
    And move away from the rest belt!
    ~Nate
    Current cars:
    FOTY 2008 winner!
      If you had a festive sway bar on there it would hold it up lol.
      But yes 3x2 angle 2x2 works fine as well and is more common I've used both without issue. I've used 1/4 inch thick but thinner would also work.
        There were photos of this fix on the site. You might try searching.
          Tapatalk is garbage for searching.
          I'll wrap it with some angle.
          Yes. Rust belt is a bad area.
