Hey guys, I tried searching and the chatbox first, so I'm here now.
Helping my brother on his 1990 Festiva 5-speed.
The car will sputter and die when it gets up to operating temperature. He changed the fuel pump last year, so it's new-ish. When this first happened he thought there was bad gas from a local station. Poured a can of octane booster and Heet into the car. Still had the issue. He has also changed the fuel filter. He also just put on a new set of plug wires.
I checked all electrical connectors, vacuum lines, and such. Everything looked fine.
I suspected the TPS (next to the throttle body/butterfly valve area), but unplugging it made no difference in the vehicle's performance.
Thoughts?
Thoughts?
