#1. The thing that is turned by the part you stick the key into is broken. This is an issue because they are not made anymore.
#2. When I mid-press the gas, the engine tends to stall.
#3. My main fuse line (the one in the middle) has fried three times -burnt straight through the copper-.
That is all for now.
I appreciate any help sent my way.
A vacuum leak will slow the engine in that case. Since you've had a mechanic look at it I assume he's wiggled all the hoses to see if any are loose? You can double check by doing the same. Some loose hoses will make the check engine light on the dash come on.
