where in the engine compartment is the horn located? thank you.
festiva horn location
pretty sure it is located behind the front bumper under the battery , you will need to look up from the bottom .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
It's behind the bumper under the passengers side headlight.
ops:
Sorry I knew it was one or the other , I never found mine ,because it was not there at all .------------------------------------------------
Z28 LS1 power 500 +
yea, under pass headlight as matt said...
but theres also a second horn wire behind the drivers headlight, just taped to the rest of the wire harness. iirc green with a black stripe? and it can be used if you want a dual-horn configuration or something...
~Nate
Current cars:
FOTY 2008 winner!
:lol: That is where I was confused , That is the wire I found and plugged my air horn into
The green one behind the drivers headlight------------------------------------------------
Z28 LS1 power 500 +
