Headgasket
  • Headgasket
    hey. i have a '91 festiva L. i bought it about 2-3 weeks ago with a blown headgasket. the engine is original and has 250,000+ miles on it. this car is my daily driver and i drive it about 15-20 miles every day. my question is this: Is my engine worth putting a headgasket on? should i be looking for a replacement engine? the oil leak has gotten progressively worse since i got it and i need a solution fast. thanx for your help.
    5 Festys and counting!!
    1993 GL auto 126,000mi
    1991 red 5-speed B6T G25 swap in progress 255,000mi
    1990 white 5-speed/Aspire swap daily driver 273,000 mi.
    1989 silver 4-speed parts car
    1989 white auto El Festivo
    1992 Chevy Silverado K1500 soon to have 383 stroker
    1999 Mercury Sable
    1992 Pontiac Bonneville SSEi Supercharged For Sale
    It just depends on what you want , do you want to do a swap to a B6 or B6T, or a 1.3 back in do you want to get by as cheap as possible ,
    You should be able to R&R the head , have it checked and just maybe get by with doing a new gasket , Buy a repair manual to help if this is your first time .
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      a head gasket is not all t5hat hard to replace, be sure to get the head planed level before reinstall. At autozone you can get the head gasket, 2 intake manifold gaskets and the throttle body gasket for 30 some bucks.
      as for the oil leak: replace oil pan gasket, and valve cover gasket. (which is included with head gasket i think)
      Run some sea foam in it for 5 minutes, then do another oil change.
      Good for basically the rest of the motors life providing not major breaks.
      -Wes
        what other gaskets should i replace when replacing the headgasket? will tearing it down affect the timing at all? NAPA sells a headgasket kit for about $90-$100. do i really need the whole kit or are there just a few select gaskets that i should replace?
        1999 Mercury Sable
          get all the gaskets i mentioned above, you'll want to replace them all
          As for the timing issue, you have to take off the timing belt, no biggie though, piece of cake to line it up
            whats the best repair manual out there for festivas?
            1999 Mercury Sable
              All I have is the Haynes , there are several others .
              Z28 LS1 power 500 +
                As long as you have it that far apart, replace the camshaft seal in the head. Mine was leaking bad.
