Does a Festiva have a horn relay?
    Originally posted by xanthinic12 View Post
    GL's really have two horns?
    Yes. so do LX's I believe.
    93 GL modyfied!!!
    :fish:
      New guy here, spent a day lookinf for the relay in the car, 3 days on the net looking for a schematic. Google Festiva Forums, found you guys, makeing the repair of the non working horn easier. Thanks
        Thats what we are here for, well partly. Welcome to the site !!
          Originally posted by 89fester View Post
          88 Carbed L model. Most of the time the horn works. But sometimes when there is more load on the electrical system (fan or headlights on) the horn doesn't work.
          Is there a relay for the horn? And if so where is it? Can a relay from another car be used assuming I can't find a replacement?
          Thanks
          89 L
          Check the contacts on the horn pad push buttons. They build up crud and make poor/intermittent contact.
            My 92 parts car does not it only has the one on the right side behind the bumper
            I belive LX was the only models to recive the dual horn
            Originally posted by ls1_se7en View Post
            I'd also like to add that the fuse for the horn is labeled "stop". I didnt even consider pulling that one because of the name. haha. Just fyi.
            Yes that is why when your laying on your brakes and the horn at the same time you can pop your fuse and loose your brake lights - happened to me before - got pulled over for not stopping at a stop sign because the officer never saw my brake lights
            92 GL - parts car
            97 aspire - parts car
            87 323 DX - daily driver
              my 91 GL only has 1, so i agree that just the LX's have dual horns.
              -Aspire brake swap COMPLETE!
