NEED HELP ASAP guys changed engine and wont turn over!
  • NEED HELP ASAP guys changed engine and wont turn over!
    Ok guys heres the deal,
    Had trouble with crank seal since I got it
    never burnt tank but took 3 crank seals.
    so I decided to put another engine I had in a Festiva long time ago which ran mint.
    Now we went to start it and did not turn over
    Rear lights work
    inside lights work
    stereo light works
    Front lights dont work
    and wont turn over.
    So now what could this be?
    All ran good before took engine out.
    any help guys I would appreciate.
    My car is 92 Festiva automatic
    thanks
    is the little wire connected to the starter too, along with the battery wire?
      ya man
      we tryied everything
      now all the lights work
      but wont turn over
        are all of the engine grounds connected?
        and do you mean the starter does not work at all???
        or does it not fire???
          no current going to starter
          but when plus directly with cables and direct on baterie it turns over fine
            check the center fusible link just behind the battery
              check the ground on the left side of the engine bay that grounds to the strut tower mine was disconnected and it wouldn't start
              http://www.cardomain.com/ride/2304767
                since the headlights don't work i'd be most likely to fault the center fusible link as mechanicaldj said... that relay will make your starter not work and your headlights go out.
                i know from experience... stuck in the rain. lol.
                ~Nate
                Current cars:
                FOTY 2008 winner!
                  yup, i had the same thing on all 3 of the festiva's i've drivin
