Well I'm trying to get the GTX to crank. It didn't come with any under the hood engine wiring so I got an alternator/starter harness for the car and installed it tonight.
Battery straight to the starter then to main fuse wire.
12 volts present at the small solenoid wire when key is cranked.
Starter will not turn.
I then removed the solenoid wire on the starter and took 12 volts from the starter and ran it derectly to the solenoid tab. The engine cranks easily.
Why no cranking with the key?
You should post that somewhere where people can see it.
