My hatch won't unlock.
  • My hatch won't unlock.
    It worked good with the squeeze release and then all at once the squeeze thing feels like nothing and the ignition key won't turn the lock. My old festive did that and I never did figure it out, I crawled over the seat once and got it to release and then it worked for awhile. Is there a cure for this.
    have you tried pulling off the inside panel to see if something has come loose from the latch ?
    91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
    93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
    1981 ford F-100 400000+ miles ? , looks rough - runs good
    1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
      if you look at the latch from the inside of the vehicle, you will see a little lever to manually unlock it, if that dont work, pull the cover off the hatch and you can push the rod to open it. Mine froze up from not using it in awhile.
      69 Shelby GT-350, 351W, 4 spd
      97 Jag xk8 vert
      06 Mini Cooper S GP
      93 Stiva
      04 Volvo S80
        will the key turn inside the locking mechanism, if so mine did the same thing i just had to take the inside panel off and adjust where the handle opens the hatch
          OK, thanks, I'll try that stuff today.
