The engine revs to about 4500 when I depress the clutch, which was recently replaced, but this didn't start happening until a few weeks after that. When not in gear, it idles so poorly that I will stall at stoplights if I don't keep my foot on the gas. I've used gum-out and spray carb cleaner, played with the throttle adjustment (which makes the problem worse).
Where are the fuel/air and idle screws on this carburetor?
Thanks in advance...
