I am re-assembling a Fesiva engine which has hydraulic lash adjusters in the rocker arms. Assembled, they are tight - no clearance between the valve stem and the rocker. That doesn't seem right to me. I would think there should be some clearance that gets closed up under pressure. The Haynes manual doesn't say anything about it.
Hydraulic rocker arm clearance?
