I have an 88 carburetted ford festiva L that occasionally idles at extremely high rpms when the clutch is pushed in. I don't have a tach so I have no idea how high it is idling but I am guessing that it is close to the equivalent of pressing the accelerator half way to the floor. In other words high enough to have everybody stare at you at stop lights, drive thru's, and of course when you turn the car off and try to convince it to stop dieseling.
This car seems to be very emotional :lol: If you push the car a little hard it does this revving thing for several days. In all seriousness you can tell when the car is going to start doing it because you can almost feel your foot catching or rubbing on something when you push it towards the floor. (Though one time I accidentally through the car into 2nd when I meant to go into 4th and it rev'd for days after that as well)
In a last ditch attempt to fix the high idle (outside my place of work) I tried to physically turn the throttle backwards. I was able to turn it about 1 degree and it did drop the rev a little bit. I also noticed that there is quite a bit of slack on the throttle cable so the pedal itself is not sticking.
I do have a feeling that something is sticking or grabbing because what I feel in my foot but what ever is going on I cannot man handle it back to a normal throttle position. Since I have a carb I am doing just about everything in the blind because I have not yet pulled off the top part of the carb.
In the past the car just seems to fix itself. I don't know if it just vibrates enough to slide back or what but I would like to have a more controlled and permanent fix to this issue.
Any suggestions would be great.
Thanks
Thanks
