fuel preasure regulator
  • fuel preasure regulator
    does anyone have a new or used fuel pressure regulator for the b6t they want to get rid of? i think mine might be bad and i would rather not pay for a new one and that not be the problem. so id like to see if any one is selling there used one if they have upgraded to a better one.
    also what are symptoms of a bad regulator?
    1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
    1993 BBF 466cid mustang notch 7.7 ltre
    festiva turbo b18 project
    2001 BMW 325i
    1996 ford F-150 sold
    When mine went bad my engine would "loop". Seemed like a bad misfire and sometimes it would die.
    Poor gas mileage, running lean, running rich, all kinds of stuff.
    Get a Fuel Pressure tester kit and test it out.
    Hook it up. If you have low pressure then pinch the return line. If the pressure goes UP a lot it's most likely the regulator. If it doesn't go up, it's most likely the fuel pump.
    You can also hook up a vacuum pump to the regulator and do a few more tests. They're in the haynes manual.
    www.dantheoilman.com
    Go ahead and ask me why
