Timing Problem????
  • Timing Problem????
    I just removed the AC Compressor components from the engine bay of my 93 Festiva.
    I also replaced the Water Pump.
    Everything is back together and running and the engine revs fine with out a load but runs a little rough, especially in 2nd gear, until you get into the high RPM rage.
    The car ran great before I did all of this.
    I also pressure washed the engine before I did all of the work.
    Does anyone have any ideas about what might be wrong???
    Is it possible that my timing is screwed up or that I may have knocked off a vacuum line?
    Any help would be appreciated.
    Thanks
    you probably have water intrusion in the distributor cap.
    Jim DeAngelis
      My timing belt was off by 1 tooth, it's fixed now and running great
