stalling
  • stalling
    1993 L, 5spd, stock,fuel injected,starts runs fine few minutes till warm then stalls,hard to restart .will run again after cools down.Replaced fuel filter and coolant temp sensor.Getting varied answers from all Ive asked so far.would appreciate any advice. thanks.
    autismmom's husband, 93L
    is there spark when it wont start? Pull a wire and put a plug in it and see if it sparks, if not something, with the coil.
    69 Shelby GT-350, 351W, 4 spd
    97 Jag xk8 vert
    06 Mini Cooper S GP
    93 Stiva
    04 Volvo S80
      ^^ Yes you need to determine if it is spark or fuel .
      Just pull the boot off the coil tower or a plug and lay the wire close to it and see if you are getting spark while cranking it , when it won't start .
      If it is getting spark , you may have a fuel pump going on you .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        autismmom' s husband. there is spark. it seems to be getting fuel and running fine until warmup.still tinkering.
          I meant to check it when it dies and won't restart .
          Z28 LS1 power 500 +
            there is spark at all times. hanes man. points me to airsensor/IATsensor . if so need top half of aircleaner housing for 90 to 93 w/EFI. dealers say discontinued can't get. junkyards don't have already been yanked/sold. does anyone have one to sell? know where to get one? thanks for advice trying everything.
            autismmom's husband. 93L
              try posting in For Sale/Wanted Forum
