This is a hard problem to describe. It happens in any gear, while cruising, while starting, more often with the engine well warmed up but occasionally first thing in the morning. Happens most often when changing gears/accelerating.
Have recently replaced fuel filter, distributor cap, plugs, wires, oil filter.
Have cycled 2 bottles of HEET throught the system and have used GUMOUT and spray carb cleaner.
It feels almost as thought I've driven into a big wad of gum. The RPMs will drop off suddenly to about 1k, and if I don't hold back my reflex and give it more gas it will sputter and sometimes stall. If I hold the gas pedal very gently and patiently to about 2k RPM it will eventually "catch" and accelerate normally.
If I am impatient and instinctively hit the gas (like you would in a car that is stalling) the car bucks and sputters like it would if this were my first attempt at using a clutch. I'm sure that's what the people behind me think.
I would greatly appreciate any ideas. It feels like a fuel issue but perhaps it is...electrical?? Any ideas? I don't like driving around like this and would like to take care of this before the snow hits.
Thanks in advance for help....
EDIT -- This is a 1988 carbed Festiva 5 speed w 88k miles.
