real wheel hopping problem
  • real wheel hopping problem
    we have a 92 festi and noticed that the rear end of the car will hop over quick if i go over a few small bumps on the road. its really bad on the highway but does in town to.
    is this a common problem or do the shocks have to be replaced?
    Or is there something else going on?
    tx in advance
    shock
    replace your rear shock...
    yvan
      Yep, time for some new rear struts. Pretty common. I'm not sure why, but the front struts tend to last much longer than the rear ones.
        Yep , very annoying ,esp when there are manhole covers every 50 feet and the same set of tires keep hitting them , It feels like the car jumps over about 6 inches on every hit .
        HD2500 Duramax Chevy
        Z28 LS1 power 500 +
          i ran over a squirrel once and the rear end hopped. the squirrel don't hop no more though.
            Struts or bent rear torsion beam. How are your tires wearing ?
              tires are wearing even, must be the rear shocks. hope they are easy to replace
                ouch, i found them in manual and they are struts. this probably means that i will have to have a shop do it because you have to compress the sping.
                does anyone have a home remedy for installing these rear struts?
                  you don't have to compress the springs on the rear......
                    only on the front because it comes out as a compressed unit, the top bolt on the rear assembly from the inside is all that holds the strut together other than the one bolt on the rear beam
                      yeah rear struts are easy to replace, as long as the retaining nut inside the swing arm that holds and doesn't come loose, because if it does your gonna need help getting it out.
                      Logan
                        yeah, i was able to change a rear spring in my driveway
                          I changed all 4 of mine with the help of a breaker bar, and a old dog leash to compress the springs :-)
                            auto zone has a loan a tool program....you pay for it and then return it for a full refund. They should have a spring compressor
