Urgent Help!!! Where is the starter relay located?
  • Urgent Help!!! Where is the starter relay located?
    I'm almost done with my Aspire. Its a 95? I just replaced the engine in it, and the starter relay is also bad. Where is it located?
    I read its behind the dimmer switch? Is that true? But there seems to be nothing back there. Remember, this is for an Aspire.
    Thanks very much!!
    how do you know that the starter relay is bad?
    and not just the starter? there is only 2 wires on your stater, right?
      no relay!!!
      30 amp fuse under hood ( black with) next ignition switch,(with) clutch pedal switch or auto trans neutral switch then (black with)starter.
      good luck
        oops ...
        with...=white...lol
          I know its not the starter. Yes, the starter has two cables that go to the solenoid. One has a bolt that holds it down, and the other is a push in connecter.
          First, its a brand new starter. Although its new, I still wanted to test it out. I had the starter installed, and attached a small wire to the plug-in post, and then tapped it with the battery (closing the connection). After that, the starter turned over.
