92 festiva will not charge new alternator battery and belt am i missing something : fixed
will not charge
battery could have dead cell...it happens. Is it a maintence free battery or is somehow the water in the cavities low??---------------------------------------------------
I have new batteries from Walmart that go bad like clockwork in 6 mos . in the Caddy , and they are the MAXX 78 .
I have also see a bad alternator ..
The last person that had this same problem , had a new battery and a new/reman alternator , It was a defective alternator !!
Have it checked to see if it is putting out anything .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
hook a volt. meter to the battery while it's running, if it's says between 12 - 14 volts the alternator should be good, and it's the battery that would be deffective
i learned that one from a friend of mine who is a 3rd year apprentice for a mechanic
